User Name missing
- Mar 16, 2009
My ’96 Ranger 2.3 is leaking anti-freeze near the firewall on the passenger side. From what little I could tell by laying on the cold asphalt and looking underneath, wherever its coming from, it looks to be dripping on the plastic wheel well , somewhat under the overflow tank, then following the wheel well slope and dripping on the ground. Without taking the wheel well out, I could not determine the exact location. I just replaced all the hoses this year and all the connections around that area seems to be dry. I did not run my hand under the overflow to see if I felt any wetness, the only line I know of runs toward the front and seemed to be dry. I started the truck and cranked the heat, but I could not tell if it was dripping worse or not. I do know the heat output has been sucking for awhile now and I had planned to replace the heater core, water pump, timing belt come spring. Also there is no anti-freeze leaking inside the cad, which is a dead giveaway for a bad heater core. Any clues?
