Triple core radiator ??
RockyRoy
Detroit MI
Greetings to all and Happy Holidays -Having a few days of here for the holidays I have a "to do list " to tackle on my truck - during the past few weeks I've been slowly been tackling a heating issue that arisen, it started with a bad water pump which seized up ,and was a bear to replace -after the water pump was installed she was inconsistent (temp wise) according to the gauge - the thermostat and fan clutch were replaced- with very little success, gauge runs 3/4 on the express way and runs high to low in the city (erratic) Finally I put my hand on the radiator and noticed the bottom of the radiator and the bottom was very cold and the top extremely hot- so now I'm thinking that I have to replace the radiator, My point being here, I could have sworn that the previous owner had said it had a triple core radiator - but yet I don't seem to be able to find one. I have a 93 ranger w/manual trans and 4.0- after this long winded post - What I'm asking for is advise on a good radiator and some direction. Thank you in advance for any help that you might give -- be well and thanks again
i dont think there ever was a 3 row. the single row was for a manual trans and the double row was for an auto trans. you can swap in the auto radiator (i would) just make sure you get hoses to make it fit. if the radiator is hot on the top and cold on the bottom, it is most likely plugged like you said, but you are making all your decisions based on a stock (junk) gauge. its worth the money to add an after market gauge so you can be confident with the readings.
ty for posting ur reply's they match exactly what I was looking for- Im heading for the 2 row your comments are matching what Im seeing on the net - not ever making one is why Im not finding one-- I tried to take the gauges out of play by placing my hand on the radiator and going for the actual feel, thats what has me heading towards replacing the radiator in a last ditch effort to regain a constant running temperature. Your comments helped alot tyvm and have great day!
If it had a 1row and you're putting a 2row in, you'll also need a fan shroud (from the junkyard) and probably both radiator hoses (new).
The auto transmission fans are also not the same (one more blade), nor are the fan clutches.
Hi, just out of curiousity did you put the thermostat in backwards? Or could there be air in the system? Just my $.02. Not slamming you or anything like that, put where all human, i just wouldn't want you buying a radiator if not needed. Hope this might help.
If the radiator was warm on top and cold on the bottom, it's plugged on the bottom. Temperature gradients should be left to right, 'cause that's how the tanks are arranged.
Now, he could try to backflush it, but odds are it's just going to need replacement anyway.
thats for that extra info, all things i didnt know....
FYI, you can use the manual transmission fan and clutch with the auto transmission radiator just fine. It's an additional (IMO unnecessary) upgrade if you really need to go there, or if you're replacing a damaged fan and/or clutch anyway.
Note that if your cooling system is having trouble at all speeds, the fan is not the issue, and upgrading it will not cure the problem. Similarly, if you aren't having trouble at idle, you won't get any benefit.
Update on heating situation, radiator was replaced today , since it was warmer
outside, a 2 row was installed - the older one had some pretty bad residue in it,
so it seemed like I was on the right path . NO LUCK ! The heat seems alot better
but the temp gauge still is very erratic (spiking to the hot end ) not very
consistent at all. There seems to be no performance issues - which is exactly
what I'm triing to stay away from, now all that is left or so it seems is the
temperature sensor, this will be tomorrows chore, Ive never been in this area
before - could anyone give me directions on replacing it. again Im running a 93
ranger 4.0 w/manual trans - things that have been replaced so far -water pump -
thermostat - fan clutch - radiator - all brand new - and replaced with in a week of
each other, the original prob was a bad water pump - head gasket is fine - runs
nice -Just temp gauge shows hot cold up and down. ty again for ur replys, there
very helpful
Are you sure you got all the air out? Does the upper rad hose pressurize?
Also, assuming new = good can get you in quite a lot of trouble.
4.0Ls can be difficult to bleed all the air out of, due to the upper hose routing. Route it as low as you can. A sign of air in the cooling system is a distinct erratic knocking sound after a fully warmed vehicle is turned off.
