Trany Whine?????
BCFD428
BridgeCreek, OK
Hello, I'm seeking techinical help with my transmission problem. I own a 1989 Ranger 2WD XLT extended cab. I believe the trany in it is a FM132. When I bought the truck I noticed a high pitched whining sound whenever I was driving in 1st, 2nd, 3rd and 5th gears. This being my first Ford, I thought this maybe normal, until a few days ago I lost clutch petal pressure and the trany started making a loud popping noise in 1st, 2nd, and 3rd gear.
I shut the truck off and checked my clutch fluid thinking I had blown out the slave cylinder. The fluid was full and after pumping the petal a few times regained petal pressure. The grinding still persisted. I then checked the trany fluid to find there was almost none in it and no sign of fluid leakage under the truck. I filled the trany up with 80w90 that the manual said to use. The grinding noise went away, but I still hear the whining sound in all gears but 4th. Is this normal or could there be a bearing going bad? Obviously I have a seal leaking either in the front or rear, but I'm concerned about the grinding popping noise I heard. Any feedback would be greatly appreciated. Thanks.
same thing almost
I had a fm145 had changed the clutch and started to bring daughter to college 4 hours a way, the thing was whining going up 95 and then pop and I'm slowing down...
so yes it could be a bearing I would keep checking the fluid...
Paul
AllenD is the trans man but I would say its the bearings on the main shaft, It wouldnt wine it forth because it is direct drive.
It DRAMATICALLY affects the stress distribution within the transmission. 4th gear is axially symmetric; the countershaft is just along for the ride.
You needed a transmission repair when it started whining. Now, you need a new transmission. You've been given a rare second warning. It's not unusual for the transmission to go from whining directly to immobilized or stuck in a gear.
This is not the clutch. The clutch has no idea if you're in 4th.
