transmission
QuakerShaker4242
Solid Axle Swap
Avon, IN
hey i was just reading up on my transmission info for my sas and i read that all automatic 89-94 2wd & 4x4 Rangers/Bronco2/Explorer will be equipped with the A4LD Overdrive automatic trans.
does this mean for my sas i dont need to get a new transmission? because both 4x2 an 4x4 had the same one? there for i would only need to get a 4x4 transfercase. i drive a 94 4.0l 2wd ranger
thanks,
Cody
All 2wd and 4wd transmission are different.
You will need a Transmission from a 4x4 truck.
2wd A4LD:
4wd A4LD:
You can see the difference in the tail housing.
hey but since bronco2s and explorers have the a4ld transmission, could i find the transmission im looking for in a 89-94 4x4 bII or explorer too?
