DEEZE
- Mar 22, 2010
- 1999 ford range
hi guys i have a 1999 4cly. Im looking into doing the 5.0L explorer swap from my reading my truck (1999 4cyl) has ABS/VSS on the rear axle, no pats,fuel pressure of 56-72 psi, and no fuel return line...
So if i use the motor and transmission from a 1996-1997 explorer that has vss on the transmission, a fuel return line, and no pats. I will have to run a return line or use 2000+ rail, and use the in tank fuel pressure regulator from the explorer...
So here's my question.
1. I have a 2wd so i will not be using the transfercase . Can i just bolt on a tail shaft?
2. Will doing this solve my abs/vss rear axle to vss transmission conflict if not what do i do?
any tips or advise greatly appreciated thanks in advance
