Transmission Vibration???
01FordRanger
When i let the clutch out with fairly low rpm's, or im driving in second with low rpm's there is a vibrating noise that can be heard from inside and outside the car. is this something to be worried about? or is it just a bearing that might need to be replaced.
thanks
It's probably your engine bogging down. What engine do you have? And does the vibration get louder as you give it more gas?
Depending on the engine, cruising or especially accelerating below 2000 RPMs is much too low. You will find you get better gas mileage and more power if you keep the engine above 2000 all the time.
