transmission swap question
saulle74
Hi, i'm new to this site looks like a good one so far. Ok i have a 1995 mazda b3000 4x4 extended cab. i bought a 96 ford ranger 2 wheel drive. they are both 5 speeds. what will i have to swap to make it work? or will it?
thank you for your time
Welcome to TRS:icon_thumby: First, what engine did your donor have?? Ranger/Mazda trucks had 3 different engines, and all 3 had different bellhousing bolt patterns. Both tranny's are the same, but if they had different engines you can take the guts from the good trans and put them in the bad trans...If they are the same engine, you will need to change out the output shaft from the 4WD to the 2WD, drop the tailshaft housing from the 2WD, and bolt on the Tcase adapter housing from the 4WD to the 2WD case, and you will have a functioning 4WD trans:icon_thumby:
SVT
