2000Ranger3.slo
- Nov 21, 2009
Alright, my wifes car... 2002 Mercury Mountaineer 4.0L V6 4x2
I have posted this concern before but have ruled out a few things and narrowed down a little as well. I just need other folks opinions. So, apparently the transmission in this ride is not the most favorite thing among people as i have heard many horror stories.
My problem is this: When you go from Park to Drive to Reverse to Park and so forth there is this annoying "unhealthy" noise. Almost like a clunk, seems to hesitate a second then clunk into gear. Yesterday i got out underneath it and checked: Trans mount is good, U-joints seem ok, differnetial is full and clean fluid, transmission may have been a little over full but is good now. Anyway, got the wife outside to go through the gears Park/Reverse/Neutral/Drive just random while the engine was running and i was underneath watching/listening.
Going from Park/Reverse vice versa there is a loud click/pop noise at the gear change area on the side of the trans. Not sure of the technical name, but where its all connected on the side of the trans to change the gear. Its almost like something is binding up but its seems to be inside the trans, behind the black module/gear selector. And the clunk noise, which usually happens going to and from Reverse and Drive, seems to be coming from somewhere in the area/maybe inside of where the driveshaft leaves the transmission.
I know this is not the best description of things but I hope that someone reads this and has an idea/thought or something of what could be going on. Let me also say, the transmission shifts smooth with no problems while your driving. Its just the intial putting it in gear that is concerning me with noises. Hope this is in the right place, its like an explorer. Thanks in advance to anyone that reads this. Let me know anymore info I may can give.
