Transmission Replacement
pblarsen
I have a 86 Bronco II with the automatic that has gone to crap. I need a list of compatible transmissions to replace it with. I found this list after doing a google search can someone tell me if it's correct? And if so are there any modifications that need to be done? Thanks, Paul
1985–1990 Ford Bronco II
1987–1993 Ford Mustang (when equipped with the 2.3 I4)
1987–1988 Ford Thunderbird (when equipped with the 2.3 I4)
1985–1994 Ford Ranger
1985–1995 Ford Aerostar
1990–1994 Ford Sierra
1991–1994 Ford Explorer
1991–1994 Mazda Navajo
1994–2002 Mazda B-Series
1988–1989 Merkur Scorpio
You are going to be pretty well limited to 85 to 94 Bronco IIs, Rangers, and Explorers if you want something that will bolt in and work.
But may I caution you to look through the Tech section, regarding replacing the auto. You may decide that another auto trans is just a wrong way to go. My own experience is that the auto is, ummm, shall we say, less than reliable. The A4LD problem thread at the head of the Tranny Forum section, is most illuminating. As always, YMMV, especially according to your experience.
