trademarked67
- Mar 16, 2008
Working on removing the transmission from 94 Ranger, 2.3L manual 5 speed 2wd to replace the clutch and slave cylinder. The truck has 195k miles and this is the first time for these parts to be replaced. Problem I am having is all the frozen bolts. On the transmission to engine bolts, at least 3 I can't loosen - the one above the starter and the two above. And is there only 6 bolts on this connection, or is there another I can't see above the oil filter? I am having a difficult time getting leverage on these bolts and there is little room.
Also, all four bolts on the rear flange of the drive shaft are frozen. I haven't tried to loosen the cross member bolts, but they look worse than the others.
I know a number of you have done this a multiple times. Any suggestions/secrets on trying to remove? I have been spraying with WD40.
Thanks
Thanks
