jtrmer
I have a 1993 Ranger extended cab 4x4 4.0 with the Mazda manual transmission. I got the truck with clutch problems. I replaced the flywheel, clutch and pressure plate and slave cylinder with bearing. Things were going great until I put the transmission in and found that the transmission was stuck out of gear. I replaced the shifter ball support cups and still nothing. A friend of mine said that I should check to see if the shifting linkage was aligned and they weren't. I aligned them and boom I was on the road. However, I have no fifth gear. When I shift to fifth it is like I am shifting into neutral. I have also noticed that the gearing seems loftily high. I can reach 55 in third gear and no were near red line. Is it possible for over drive to remain locked in gear while going through the other gears and then be shifted out of gear when shifting into fifth? jtrmer@nctv.com
