Transmission questions
fellows86
Dunnville,Ontario
when using a T5. What are you guys doin converting it to hydraulic or using the cable style if so how are you doin it any addvice would be great or should i say screw it and put a c6 in it ? by the way the it is a lowered truck
It's really easy to use a hydraulic setup with a T-5. There are lots of external slave kits to choose from. All you really need to do is adapt the hard line to the slave cylinder.
