Transmission noise
Lineforker
Hey guys, I got a 1989 ranger 4x4 with 49,000 miles. It was a one owner when I bought it, but the clutch was slipping. Changed the clutch and noticed the transmission making a grinding noise plus when you let out on the clutch it's not smooth. It feels like its jumping. At a loss! Open to all suggestions.
Nice find id like to see pics. Did you change the pilot bearing, check clutch resevoir and trans fluid?
Sent from my LGL16C using Tapatalk
Grinding noise could be a bad input shaft bearing. But the clutch not being smooth indicates to me a possible throwout bearing issue. Hope this helps.
I want to add one more thing as I don't know your skill level: Did you possibly put the clutch disc in backward? believe it or not even experienced mechanics have done this not paying attention/ in a rush. it does happen
Llineforker
Sorry so late but been out of town for awhile. I changed the pilot bearing, the throw out bearing and the disc is in correctly. It mostly does it in 4th and 5th and you can hear it a little in 3rd. Kind of sounds like noisy synchronizers. Open to all suggestions.
Drain and refill the transmission lube. I did a clutch job on the Rat. My only mistake was re-using the transmission. Less than 5 K Miles after the clutch R+R, The shift fork broke and dropped into the gears. 1400$ later, the Rat runs better than ever.:D
What engine? 89 seems to be a change-over year for trans type...
If 2.9, I would grab a 4.0 M5OD from a 4.0 4x4 and call it a day. May also need shifter/etc...but should bolt up-ish. :)
http://www.therangerstation.com/tech_library/ManualTransmission.html
It's a 2.3 and already has a M50D. I am jut perplexed that it started doing it after the clutch R&R. Just dropped it changed the clutch, pressure plate and slave, then put it back in. It's driving me batty.
