xfrog
- Sep 26, 2008
1993 ranger 4x4, 4 liter, 5spd, manual 4wd. Problem is a "chatter" type noise under acceleration (anytime throttle is applied) in any gear at any speed (louder at road speed). Noise seems to emanate from around or below the shifter area. If I let off the throttle and coast, the noise goes away. Other than that, the transmission seems to work fine, shifts smooth and clean, no vibrations, fluid level is good. What could be the problem?
