ForgedCrank
- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
1994 Ranger 2.3l 5 speed
Hi again folks, wanted some opinions if you guys are willing...
I know this has been covered ad-nauseam, but I'm just looking for some validation on transmission types and models, correct parts.
Everything I read (for the most part anyway) is regarding the M5OD and some variations o fit. My particular gearbox is labeled as F27A UA which is, best I can tell, a "M5R1".
Is this the same thing as M5OD-R1 ? I'm experiencing what I believe is the common leak from those top plugs and want to get them replaced. It's a very slow leak, but it's gotta go. Leaking oil isn't tolerated.
Would this be the correct plug to get?: M5R1 M5R2 Shift Rail Top Cover Plugs Ford Mazda Rear Updated Steel Ranger F150
In addition, I figure might as well fix the sloppy shifter while I have it opened up. Would this be the correct kit?: Ford M5R1 Shifter Repair Kit Fits 1988-up Ranger Explorer 5 Speed M5ODSRK
Also, what are your opinions on those plugs? Would you guys do this, or find the original style rubber ones? I don't know if I'm going to have enough room to pound in the steel ones or not.
Sorry for the redundant questions, I'm just hoping for verification before I order the stuff to make sure i'm not screwing up.
