- Oct 12, 2010
I have an 87 ranger 4x4 5spd (fm145) with a 2.3l diesel, it will move but not without a whole lot of force applied via the engine. When I put the shifter in neutral and release the clutch, it will start to move forward, put it in reverse it will move forward a few inches POP!! then move backwards but like its binding up. Its the same in every other gear. I also drained the fluid and dropped the pan and couldn't find any metal shavings or obvious damage.
My question is this, what would have caused this?
And also, what other trannys will bolt up to my bellhousing?
Thanks for the help
Thanks for the help
