sean9721
Today I did 2 burnouts at stop signs. I didnt power brake, I just floored it and let off the clutch. The first time the gear shifter moved to the right but I didnt think anything about it because it felt like the front end of my truck came off the ground, which I dont think it did. At the second burnout, I noticed that the stick moved over to where it would be when I'm in 3rd gear, but I was in first. I didnt notice any weird noises and everything feel fine while I'm driving. I also noticed that once I'm off the clutch in first, when I floor it and let off to shift into second, the stick will move back to the left. So when I floor it in first it slowly moves to the right, and then back to the left when I shift. I havent noticed the problem in any other gears. While I'm letting off the clutch in first, I also noticed that the stick will move to the right. When the transmission is "flexing" the whole cab shakes. I also noticed that it only moves when there is a good bit of torque on the motor.
I know that spinning the tires wasnt the smartest, so I take responsibility for my actions.
