- Aug 10, 2007
- HIGHLAND, MICHIGAN
not hard to do, just need an floor jack and a block of wood or ideally and engine hoist. if youre using the jack method you will have less room to move around under there as the nuts and bolts that hold the mount in are on the bottom side of the engine crossmember. the mounts are keyed (only go in one direction via a round pin) and as long as the bolts arent too rusted you should have it done in a couple of hours.
