If you take off the connector it unscrews from the transmission
In side the trans on the shift arm is a Cam that moves the plunger in the switch up and down to connect key to starter motor in Park and Neutral
AND to connect 12v to Reverse lights when in Reverse
Don;t have a 1988 wiring diagram but should a purple/orange wire that has 12v with key on, and then a Black/pink stripe wire that runs back to Reverse lights, those two are connected when switch is in Reverse position
Hm what is the red and brown connector called
I looked up tcc connector and the only thing that pops up is the tcc solenoid inside the transmission
Also I looked up back up light switch connector and the same connector with the red and brown wire
Is the same as the one I saw even with the same wire color you described
For
