- Aug 6, 2007
- Age
- 40
- Westport, WA
You can over cool a transmission. You should never eliminate the cooler in the radiator because it is also a fluid heater.
beat me to it. what the stock tranny cooler is designed to do is keep the tranny the same temperature as the engine coolant. your coolant temp is actively controlled via the thermostat, thus your tranny temperature is regulated.
since your stock setup is regulated, having the tranny run at 200* doesnt give you any indication of how much of your cooling capacity is used up. what you should do is hook up your trailer and go for a tow. if your tranny temperature climbs higher then what you experience driving around normally, you know your at or over the limits of your stock system, and are in need of an additional cooler.
i hope that comes out clear
