Transmission & clutch
Engine goes vroom and truck doesn’t move.
Might be better if you explain your problem/symptoms so that someone experienced can try to help.
Well , it’s just whenever I step on the clutch it sounds weird , I want to describe it like when you turn the switch on a car and you hear that little sound of the fuel pump I don’t know you have an idea , but when I step on the clutch that how it sounds till I take my foot off , when I go into gear it’s okay , but once in a while if I’m going fast like in the highway or passing a speed bump (obviously not fast on a speed bump) it kinda stumbles . Not sure if it’s the clutch, and if it can hurt the trans in any way
