Transfercase swap.
Wilcox
Forum Member
Olympia washington
Swapping out a touch electric transfercase to manual. Is there going to be any electrical problems doing this. I have manual hubs also. Any suggestions or issues i should be aware of before I start project? Thanks.
Forgot to mention this is a 1988 ranger.
Not positive...
But if your manual linkage bolts to the tailshaft housing... not all of them will have provisions to do so.
For the electrical... I don't think there are issues. Speedo is cable. Pull the fuse... tape things up just in case you have to go back to electric... it will all still be there.
Also moved you to the transfer case forum...
Electrically, no problem. The only issue I see is what Gump mentioned. The shifter linkage mounts to the transmission tailhousing. Your tailhousing may or may not have the threaded holes prepared for that. You may need to get tje tailhousing off the donor truck, if it's he same transnission. Or you may need to drill and tap the holes into the bosses molded onto the tailhousing. With both trucks being 88s, your chances are good that everything is ready for you. But no guarantee.
Are theses the 2 hole you mentioned on tailhousing. If they are yes both on donor and my truck are both threaded. Please confirm this is what we have been discussing. Thanks again. Just want to make sure things go in smoothly. Also having a heck of a time getting shift knows off. Really dont want to put vice grips to it?? Any suggestions there as well?
  • Transfercase swap.
Yes. Those are the holes where the shifter will mount.
Concerning shift knobs, they aren't meant to come off. They are NOT threaded on like most others. They are molded on over splines and a lip. Careful application of heat might soften them enough to be removed. But, best thing is to just leave them on.
On my first F150 ('88 4x4), the main shift knob eventually got loose to the point where I could spin it and feel the splines inside slipping. But it never did come off. Also, the little disc with the shift pattern on it will get loose and rattle and spin as you drive down the road. But it's held in a deep groove and won't come out easy either.
@Wilcox
I am about to install a manually shifted A4LD and transfer case in place of the electronic shifted A4LD and transfer case that were bolted to my doner 1994 Explorer's OHV 4.0l.
If you have all the manual shifted transfer case's linkage and floor shifter, it should go well.
I hope that the Explorer's column shifter in my rig confuses any potential thief!
The shifter and knobs are splined . They are glued on. Don’t twist the knob . Get under the knob ,I use vise grips larger than the shifter and smaller than the knob, tap the vise grips with a hammer and the knob will come of . Glue it back on when done . I’ve done both of my grandsons . One 8 years ago the other 3 .
Dose anyone know if some one sells the plate on top of the manual transmission with the small rubber boot on my 1988 manual ranger. Also wouldn't hurt replacing the interior boots and trim plate. If there's reproduction please let me know. Thanks again
AFAIK, those parts are all junkyard only. I opted for a DIY solution:
Transfercase swap.
The steel part underneath was from an automatic truck. I cut out only as much hole as I needed. The transmission shifter is just a round hole. The plastic part is cut from the floorboard of a side-by-side.
