Transfer case
Super ranger 01
Cumberland Co.Tn
I just checked the fluid in the transfer case...i know by the finger test into the hole how to check it are you supposed to add automatic transmission fluid here... or does it cycle through the transmission. Thanks for any input
Transfer case should not be sharing oil with the transmission. Yes. Add whatever fluid the owner's manual recommends, through that hole. You can get a cheap plastic pump at most automotive stores that will make it easier to get the fluid into that hole.
