How do I separate the trans case from the back of the the transmission? Other than just the bolts. What do I need to keep mind of? As in gear positioning or anything like that?
Hey just finished up yesterday. The trans case was full, all I did was undo the lower filler plug and drained all the fluid which made it alot lighter.
For anyone doing a transmission pull/ transfer case pull in the future... It's easiest to to remove the trans case first, after draining fluid, keeps the transmission from twisting around during removal. But, there is a gasket between the two, trans and trans case. I didn't replace mine it was still fine. But if you take yours apart and need a new gasket you might be SOL I couldn't find at any parts store. And I tried all of the ones in my town. Autozone, napa carquest, and kragens
since there is a DRAIN hole at the bottom of the gasket area (look close, you'll see it), don't worry about the gasket too much, I think it's more to keep the two from corroding together...
