Got a 2003 B3000
Does the transceiver module, key ring and black box under the ignition, need to be programmed or anything special once installed? Or just disconnect the battery and install.
It sounds like it's just an antenna. Only the key, pcm and pats needs Ford's help.
I just got done rebuilding the motor and everything was going great. Only damaged wires are the ac and two fuel injection terminals, rest of the wires look brand new! Was going for a test drive and wouldn't turn over. Starter is good. Just flashing thief very quickly
Forgot I left the key in it, in the on position, for about 30 mins and it just started working again!
It's got over 300k miles and it was a bit nasty under the cover so Im thinking it's worn out.
