trans swap
indymadcaster
ok, folks I have an m5od and the manual trans case from my 1988 bronco II (it is a 4.0 m5od i rebuilt it and I put it in it)along with the manual shift transfer case with the big clutch 4.0 flywheel/ perm magnet starter swap
it is going in the 1994 explorer i have with a bad auto trans and electric Trans case......So question is what years and model clutch and brake pedal bracket under the dash do I need? :icon_confused: cannot find a 1994 explorer manual truck @ pick a part or will the one from the BII work????
I do have the 4.0 man PCM for a 1994 and all the stuff on the BII(clutch, flywheel, slave, master, starter) so all I need now is the pedal bracket.
many thanks
Indymadcaster
looking at this it appears i can pull both dashes back using the clutch pedal, brake pedal and the clips and spacers from my 1988 and its cross shaft and put them in the explorer support bracket........................
When I did my 93 ex I got a pedle assem from an ex. I think they are the same as the other rbv's but I wanted to be sure. R &r of the pedle assem is a bit of work, when my friend did his he just used the pedles and was able to wiessel them in without taking the whole thing out. Hth
Jonathan
I put a 93 trans in a 91 ranger 4x4. I swapped the pedals because the assembly looked like a chore to swap. You might get away with the 88 if the brake pedal pivot is wide enough. I tried to use an 87, and found out that the brake pedal pivot was too short by about 1". The wider assembly is harder to swap. I had to pull the wire harness out of the firewall, and disconnect the emergency pedal from the wall and slide it down towards the floor to be able to slide the clutch pedal & shaft assembly out of the brake pedal and the bracket. It wasn't that bad, once I new I was going to have to get the other things out of the way. It just barely clears but it is way easier. You need to measure the 88 brake pedal width to see if it matches the 93.
