- Nov 27, 2011
- Automatic
ok, folks I have an m5od and the manual trans case from my 1988 bronco II (it is a 4.0 m5od i rebuilt it and I put it in it)along with the manual shift transfer case with the big clutch 4.0 flywheel/ perm magnet starter swap
it is going in the 1994 explorer i have with a bad auto trans and electric Trans case......So question is what years and model clutch and brake pedal bracket under the dash do I need?
cannot find a 1994 explorer manual truck @ pick a part or will the one from the BII work????
I do have the 4.0 man PCM for a 1994 and all the stuff on the BII(clutch, flywheel, slave, master, starter) so all I need now is the pedal bracket.
many thanks
Indymadcaster
many thanks
Indymadcaster
