Jspeed4x4
I have a 1993 ranger splash 4.0 4x4 with a superlift 5 1/2" stage two lift kit and superlift steering kit. i have problem that every time i hit the gas hard it fills like the trans is hiting the under body of the truck. i have check the trans mount and even replaced it but did not fix the problem.what it fills like to me is that the axle is shifting a little forward when hard on the gas.truck has stock rear leafs and a add-a-leaf sitting on the stock block and i added a 3 inch block to level truck ride. I have check al bolts and hardware are tight. any help with this would be great. do i have to much drive staft angle. i'm worry that if i wheel to hard that something is going brake and leave me stranded
