80351
I have a 92 Ranger 4.0L 2wd with an A4LD trans an I'm having problems with what looks like trans fluid in the oil.
Before anyone asks, no there is no signs of having water in the trans fliud which elimnates the radiator trans cooler, there is also no signs of water in the oil however the oil on the dipstick is way past the full line, was just changed but like I said has a redish tint to it like it has trans fliud in it an I finding out the trans fliud is always very low. I see signs of fliud leaks underneath the truck but none that would warrant the amount of fliud I am using.
My thoughts are that the vacuum shift module is bad an sucking the fliud up into the engine an thus into the oil, I don't know of anyother way trans fliud would get into the oil.
Is this possible.
Thanks in advance for your assistance
Dave
Is this possible.
Dave
