tranny's in
emo666
michigan city,Indiana
Tranny's in--- worked in with different size bolts. Didn't want to do it that way but nothing else was working. Right towards the end got that POP and in she went. I only used a 3/8 ratchet so I didn't bind it up to tight and screw something up.
I think I'll go with 80 weight oil cause I think that was what's in it now.
Now I'm bleeding the clutch hydraulics which ain't workin to good either.
Everything was working before but I cleaned it all up. Adding new brake fluid dot 3. I get a good steady stream from the top of the slave cylinder but no clutch action. Where's the air hiding?? I'm doing this by myself by blocking the pedal to the floor then bleeding. OR do I need to have someone pump it up and hold like brakes??
Thanks for the help guy's
P.S. looking at 1989 bronco 2---nice shape but a little pricey--we'll see??
