mjchris
i am having alot of trouble finding an a4ld for my 87 2.9 4x4 ranger.i found one that is in a 2 wheel drive, will it work ? or is there another tranny that i can use ?
Any 4x4 tranny from a 2.8,2.9 or 4.0 will work(all 3 are the same class engine and have the same engine to tranny bolt pattern). The only thing is the trannys are different lengths so driveshafts would be different lengths also.
http://www.therangerstation.com/tech_library/AutoTrans.html
http://www.therangerstation.com/tech_library/ManualTransmission.html
To swap in a manual you will need the pedal assembly, clutch master and slave cylinders and the computer from the manual donor.
