wisconsinranger02
- Sep 3, 2010
Hey all you experts, I need some advice, or confirmation with a transmission problem. First, some history:
My ride is a 2002 Ranger, FX4, loaded, manual 5 speed and transfer case. I average 23K miles per year, all highway. I usually get 95K miles per set of tires. The clutch slave cyl died at 85K, replaced. I have some of the typical probs - rusted Ebrake cable, pass door sensor (someone PLEASE tell me what wire it is so I can ground it and MAKE IT STOP!), bad ABS sensor (never liked them anyway), and recently the blower motor resistor. Good news? I've had a tree (18" in dia) fall on the A pillar and didn't even crack the windshield. No interior fading, paint is perfect, and truck runs great - not bad for 181,000 miles.
OK, last week I noticed a "rotational" vibration in the gearshift, like you could feel the second gear moving. Shortly after that, it got hard to mesh - would grind anywhere about 15 mph. Two days ago, it stopped meshing completely if I was rolling, and about the same time, when it WAS in second, average to hard acceleration produced a severe vibration/chatter/bucking - like the second gear sprocket (?) was slipping on the shaft....since then I have stopped using second, going from 1st to 3rd. All the other gears are fine, no problems, and clutch action is firm with no excess play, and no unusual noises.
I know it's going to be a tranny shop stop, but I would like to know what to expect...what did I break or wear out?
Thanks for the help - and BTW, for you guys that don't buy the tree tale...here's proof - 12/22/2006:
Doug
Doug
