tranny swap help!!
rangerluigi
i have a 02 xlt 3.0 with a 2wd auto trans. im wondering if i find a 4x4 auto trans for the same year and motor, it will bolt up right? :icon_confused: and im planning on getting a manual tcase also because of the reliability and its easier so swap in :D. and if anyone knows the year range for the trans that will bolt up, that would be great
thanks alot
thanks alot
you know you dont need a new trans to make it 4x4.
All you need is a tail shaft, and housing from a 4x4.
I just converted masterbrendon's 4r55e to 4x4.
from '97 to current for the tail shaft, and '89 to current in the tail shaft housing.
cheeper than buying a new trans...
alright, so just replacing the tail housing and tail shaft sound way cheaper... is there anything to worry about like spline count or that sort of thing?
could this be done with any trans and is it just as reliable i have an 88 a4ld
