eyelovefords
you want to replace the clutch disk, pressure plate, throwout bearing, and slave cylinder (usually TO bearing and slave come together). you'll also want to have the flywheel dressed.
getting to the clutch is a pain....do it right the first time so you wont have to do it again for another 130k.
Hello, I am new to this site so, please forgive me for posting in the wrong place if I did. I just seen the MDO5 and I think this where I ask Q's about it.
I found it when I was looking for answers to my tranny problems. Mainly how to gravity bleed. What happened was my tranny was making a really loud grinding noise. I was told that I needed to replace my throw out berring. Well, I went and bought a clutch kit and while I had the tranny out I had my flywheel dressed. Put it all back together and it all worked for about 2 weeks and the grinding noise came back and I got stuck in 3rd gear.
I was told at that point I had to replace my clutch master cylinder. So I did and when I went to bleed it again, I found that my hydrolic line was leaking at the plug. So, I went and baught a new one and in the process of bleeding I found at the last few steps of depressing the cluth slowly for 2 seconds and then letting up on it fast that I have a leak coming from the bell housing. I asked Q's again and was told my slave cylinder is bad. I am frustrated and confused. I love my 89 Ranger and don't want to get rid of it. So, any suggestions would be great. I want to fix it and replace anything that might be a problem later so I don't have to pull the tranny again. I think pulling it 2 times is more than enough.
Oh, and this is my very first time working on a tranny. I loved every minute of it and followed directions step by step. However, the only time I have to work on it is on holidays and Sundays.
