Tranny Cooler for Explorer
If a stock size cooler will work for you, I see them in the pick-n-pull all the time and can be bought real cheap compared to a new one. You can get some lines/hoses/fittings too.
Should have a cooler in the rad and an aux. cooler infront of the rad. passenger side, they are about 8x10 or so...
The extra cooling won't hurt anything. I replaced my stock one with a 12x20 flex-a-lite tranny cooler.
I just removed the factory one, hooked the lines up to the new cooler with the supplyed clamps and mounted it onto the radiator with the supplyed hold downs for it. They are a plastic 'bolt' that you put through the fins of the rad and the cooler and then tighten down the plastic nuts that come with it. Everything came with my cooler that I bought.
No, but I could grab some.
cool, thanks...in your opinion..does the A4LD suck like everyone else says..because after i get all the little lift things sorted out im going to rebuild my trans....just some input is all im lookin for..
Thanks
