- Sep 22, 2007
- Michigan
- 2.9 V6
- Manual
- My credo
- A legend to the old man, a hero to the child...
I wouldnt try it with a ranger personally
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
A tractor that small you “might” be able to pull on a trailer with a ranger , I brought my 63 ford 2000 home on a small tandem axle trailer with a V6 escape 50+ miles from home with no issues. I did try using my ranger once to tow it to a small show, was way too much for mine, wouldnt want to do it again.
Ive hauled and pulled alot of heavy shit with my rangers too, just the older i get i guess my balls of steel have turned more into balls of foam rubber.I did a 4300lb trailer/gravel load behind my 87 Ford Ranger...it did it, it didn't like it, and if it weren't for being in town I never would have done it because the trailer don't have brakes. Slow back roads driving on the way back home without an issue, but certainly would not do that again...it was the only vehicle I had, the Explorer was in the shop having the wheel bearings done at the time, and was in the middle of a project at the house where I needed more gravel/dirt. Definitely not a good tow rig LOL...the Ranger has the 5 speed which I think if it were the automatic it would have done better, but trying to limit slipping the clutch with that much weight just don't work so well LOL.
Hmmm...
Hmmm...
Maybe i worry to much. I bet with a frame hitch my 87 would handle 2 800lb quads on a 2500lb 18ft trl huh?
I also have an F250 so i dont really need to use my ranger like that anymore.That’s a 2200lb 18’ car trailer, electric brakes, with at least 2500lbs of tractor. I’ve towed cars with this setup too.
No problems, except the springs are clapped out.
That more from long term abuse them a single situation.
Wait a minute....isnt that a 3.0 too?That’s a 2200lb 18’ car trailer, electric brakes, with at least 2500lbs of tractor. I’ve towed cars with this setup too.
Im relieved. If it was a 3.0 i was gonna have to go load something heavier and bigger on my 2.9 to retain superiorityClose. Supercharged 4.0 SOHC.
