Trac-lok rebuild
coffee
Buena Vista, Ga.
Has anybody tried the alternative stacking of the plates in the 8.8 Trac-lok?
I've read the instructions on the rebuild and they look pretty straight forward, I was just wanting to find someone that had done this rebuild, since Murphy is a very close, constant companion. Are there any idiosycncracies or littlte things I need to look out for while doing this rebuild?
It's quite straightforward really. Just make sure you soak the plates and clutches with lubricant before you assemble it. If you shim it as tight as it will go it works really well. It's no locker but probably the next best thing.
Thanks for the info. I guess the next chore is to go find the parts. After this, finish the interior.
