cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
So I tried adjusting the thing with a voltmeter, got it .998 v at idle. But I kinda screwed up. I didn't know what I was doing and started touching random probes from the tps to its connector.. Finally I plugged in the tps connector into the sensor and stabbed the positive with a needle and got it to show my desired volts. Turned the truck on and now it's idling super high and when I let off the gas it goes up to like 2500.
So replaced the sensor and it's still doing it.. Did I totally screw up everything? Did I fry my computer?
It's showing p1506 idle speed too high
