TPS readings
jamie18
pinetown nc
94 ford ranger
intresting question I was just doing some checking on the tps per tech library I probe the wires and check readings to see if it was off and it reads backwards from library at closed throttle it has 3.88 volts at closed throttle it reads 0.66 volts. maybe dum question.:3gears:
Please check/edit your post...which one is closed?
Richard
