artistic_gore
Hi,
I've asked this question in a couple other places only to be shot down/laughed at or just ignored.
What I would like to do is take an '89 2-wheel drive bronco II and convert it to 4x4 and SFA at the same time. I was thinking of running toyota axles to stay close on width but having the option of beefing up the internals later. Unfortunately the toyota is passenger side drop. This got me thinking of running a toyota transfercase as well. I've looked and couldn't find an application specific adapter. The only way I can think to do it would be to use the tail housing off of a 79 or 80 toyota L-43 trans, have a custom input shaft made and an adapter plate maybe 1/2 to 1" thick to run bolts into from either side (maiting the trans and tail housing). I guess I am curious if; A. this would/could work, or B. if it would make the rear drive shaft too short or would otherwise be impractical.
This winter I am starting a mechanical engineering/design program at a local college and on the side while doing my regular class-work I would like to design the parts for this (if it has any basis in reality) and if the resources are available, have the parts machined at the school. I may even go so far as to have a whole new housing done and eliminate the need for the spacer/adapter between the trans and tail housing thus eliminating appr. 1" out of the overall length.
I think even if I have to purchase a whole 79 or 80 toyota for parts I could probably keep the cost of the conversion under $1000 if I did most/all of my own work.
BTW, the truck was free.
Sorry for the uber long post but thanks for reading,
Bryce
Bryce
