fastpakr
Forum Staff Member
TRS Event Staff
- Aug 6, 2007
- Roanoke, VA
- Automatic
- Tire Size
- 285/75-16
I've been helping a friend with his '90 4Runner. Trying to chase down a soft brake issue that existed when he purchased it. Rear brake components appear to be brand new, and we put on new front pads and resurfaced the rotors a couple of weeks ago. Also completely flushed the brake fluid and bled the system carefully. All said and done, we haven't managed to eliminate the spongy brakes. There is feedback to the pedal, but it is limited and you can push the pedal to the floor without that much effort.
I haven't found any sign of fluid leaks. At this point, is there anything else to check except ballooning rubber lines before replacing the master cylinder? I want to make sure that if we replace a part we get it right the first time.
