plinker
I'm looking at picking up a Bronco 2 (manual trans, 4wd), and will likely have to use a dolly to tow it with. It's got a electric shift transfer case, and it's apparently stuck in four high, I do know the trick to pull the shift motor off and switch it to the neutral position though.
My question is, am I better off just pulling the drive shaft off the rear end? It would probably take less time. Is there any problem with just pulling the shaft off?
Thanks
Thanks
