B30004X4
Just wanted to let everyone know that the article in the tech library on where to put tow hooks is not good advice if you use them at all. This past fall i put them on the bracket which is also for your bumper like the article said. This metal bracket is also wayy thinner than the frame. Anyways first time someone went to pull me with the left one it bent the whol bracket causing my bumper to be shifted towards my tire! I had to take the bumper off and bend the frame bracket and bumper bracket back. I had to heat it up with a torch and use a hammer.. what a pain in the ass just trying to get front tow hooks. Now my bumper is good but not perfectly lined up because i just bent the bracket back by eye. I have since relocated them to below the frame rails facing down and they work great. Small bolt through the frame. Then just impacted the nut on. I dont have my lower valence though so you would need to cut into this
