Tow bar install
Skelly94x4
Law Enforcement
San Diego
3.0 V6
I have a 94 4X4
Anyone install a towbar on the front bumper?
I have a pathfinder and looking to tow my ranger down to San Diego.
Just looking for advice, thanks.
I also have a 94 4x4. Not a tow bar on the front bumper, but one below it. Ended up going with a Reese 65107 front mount. Its tucked up pretty nice. I did end up totally removing the lower air valence. One could trim it rather than totally removing it i suppose.
I don't think thats what he's talking about. That is a receiver hitch. I believe he wants something like this.
I kind of figured.
There's also a problem with "flat towing" a ranger equipped with the electric t-case selector, if that's what you have, (I don't remember what year the Ranger started using them) there's no easy way to put it in Neutral. Flat towing with the t-case engaged/ engine off can cause bearing problems. You can select N by unbolting the electric selector off the t-case and manually turning the selector shaft, or you can drop the rear driveshaft while you're towing.
Mid 80's
But it's not on all of them... hit and miss, I prefer manual obviously like I strongly believe my '00 V8 Explorer Limited should have come from the factory with the manual 4406 transfer case... it's handy! Except right now with a broken passenger side motor mount, can't use low range reverse...
I have a 94 4X4
This is how I attach my tow bar to my rangers. There is a 1/4" thick plate that I put inside the bumper to spread the force of the bolt head from pulling thru the bumper. Also have chains attached to the frame.
It's how I towed my race ranger before I got a trailer. But if I was towing a lot I would build brackets off the frame to attach the tow bar.
