I am not sure it is a good idea to get in the middle of this but here goes anyway.
Michael and Alan, it seems you are both right but are talking about different circumstances. Alan, you are talking about the operation of the clutch overall and Michael seems to be talking about the clutch in a specific situation.
I have to agree with Michael regarding regarding clutch slippage while going down the road. If the clutch does not slip empty it should not slip while towing. This has nothing to do with start up problems, only after the vehicle is moving and the clutch is already engaged (not heated from slipping). The clutch will slip at a specific torque level and having an increased load will not increase the torque put out by the engine. If the vehicle is empty, at WOT the torque is used to accelerate the vehicle. If the vehicle is loaded, at WOT the torque is still used to accelerate the vehicle and load but at a slower rate.
Say the clutch is rated at 250 lb-ft of torque and the engine produces 200 lb-ft of torque. A load that requires 275 lb-ft of torque at the drive shaft will just bog down the engine until the driver wises up and down shifts the transmission to multiply the torque output of the transmission. The clutch will not slip until it gets worn enough that the rating of the clutch falls below the 200 lb-ft level.
If the clutch was very slightly slipping at WOT in a vehicle without a load it may be hard to detect but would become more apparent in a loaded vehicle because the slippage would probably occur over a longer time causing the clutch to heat up more and resulting in more slipping. That is a different circumstance though.
The clutch function and durability at start up is a whole other thing and Alan has that covered.
I use a Brute Force clutch when I replace an OEM clutch. I tow a lot and have had good results with them. I am sure there are better clutches but I know what works for me.
