Umm, Dustin, your engine puts out a certain peak torque. Floor the throttle near the torque peak and you'll see it even with a completely empty truck. Just how does a 4000 lb trailer make your engine more torquey?
Sure you can burn out any clutch by being stupid with the slipping. But it's only going to slip if YOU tell it to, so that's driver error.
Mike, I grew weary of telling you this but I'll try one more time
You are wrong, sadly you don't know how wrong you are, but I'll keep trying....
the factory clutches for all but the 4.0 engine suck sweaty balls.
It is INADEQUATE out of the factory, Re-man clutches aren't any improvement, and some of the aftermarket ones are just as crappy.
The reason the clutch SLIPS is because NORMALLY there isn't sufficient resistance against the thrust to allow it to slip
Look at another item that slips... Why do tires slip?
When the force exceeds the grip slippage occours
while you say the engine doesn't produce enough torque to make the clutch slips and use indiuctive reasoning to imply that the engine is making more torque to make it slip you are plain and simply wrong, you are looking at the wrong end of the equasion... there isn't enough RESISTANCE against the force available to make the clutch slip, but when you add resistance it does slip...
when the resistance against the force increases slippage WILL occour unless the clutch has sufficient grip to prevent it.
Without the 4000lb trailer there is insufficient resistance to prevent the truck from accelerating, with tongue weight the tires are less likely to break loose. something has to give and to use an old saw, the weakest link in the chain lets go, in this case the clutch...
I say again for clarity the stock clutches suck hairy balls.
It's partly because in most trucks the axle gearing is
simply too damned tall and the fairly tall reverse and first gears
only aggrevates the situation further.
This is why I have been advocating the 4.0 flywheel and clutch for the 2.9 for six or seven YEARS, failing that (the the 2.3 and the 3.0) I really liked the Centerforce2 clutch (NOT the dual friction with which I have NO experience) that I used on my 2.9 before I discovered that the 4.0 clutch was a bolt on (With the 4.0 starter)
EITHER extra engine power/torque OR more vehicle mass completely changes the entire part survival equasion.
If you are an engineer I shouldn't need to explain it to you.
I do know that if you designed aircraft I would now refuse to
knowingly fly in one you designed....
I know that I tried several stock-type clutches on the 2.9 (and that includes TWO ford replacement clutches In FORD boxes) and liked none of them but I didn't have to hate them long because none of them lived longer than about 20K miles, then I tried the CF-2 that clutch lasted 115,000 miles and it was working when I replaced it, and I only replaced it when I did because I was installing a younger engine and a rebuilt transmission prepping for a trip to Oklahoma and didn't want pull the trans again to replace the clutch three months later it was at that time I put the 4.0 clutch in behind my 2.9 and I never looked back... (Now I have a 4.0 in front of a 4.0 clutch)
Extra grip isn't going to hurt a damned thing
Extra temperature resistance in the clutch isn't going to hurt anything either.
Infact improving the clutch at the very least isn't going to hurt anyone's truck so WHY IN THE NAME OF GOD do you keep recommending against upgrading clutches?
Mike, I'll make you an offer, I'll assemble a truck just for you
Put a stock clutch in it. Hitch it to my 1880lb dovetail trailer then have you back it into it's parking place.
Or you can use the NON-4.0 RBV with a stock clutch of your choice... BTW, no cheating by using low-range!
after that you can appologize to every person you've called incompetent over the years on this issue.
AD
