Touch Up Paint
Timo99
Maury, NC
Well, yesterday after i washed my truck, i noticed some small dings and scratches that had either started rusting, or had the potential to rust. I dried it off and applied some Rustolium white paint. It looks beautiful until you get really close, then you can actually see a difference. I'll have pictures up soon, probably not today because it's snowing outside, but eventually.
It's snowing in North Carolina??? It's just cold up here in New Hampshire, no snow in the long range forecast either.
Duplicolor touch up paint is usually a very close match, but make sure you use a clear coat if the original paint is, or it will end up being flat instead of glossy.
Timo99 are you full time or volunteer at your FD?
John
It's snowed twice this week, even though when it hits the ground or anything else it instantly melts, so it's more like rain. I'm a volunteer, and i plan on being a full timer on Rocky Mount's Fire Department after i get through the Fire Academy.
