Soft Touch interior paint
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Millersport, OH
Does anyone know where to get something similar to the coating used on the 95+ radio bezels and Expo center consoles?
I found one place, but they want $240 for the resin, hardener, and thinner...I don't need 2 qts of it either.
http://www.alsacorp.com/products/softtouch/softtouch.htm
I thought about plastidip but Im scared it will start peeling and chipping being in a spot that sees a lot of contact.
Sent from my XT907 using Tapatalk
Just use DP805 to fix any cracks or holes then wrap it in vinyl.
I want it to match the other stock pieces that are also coated in Soft touch....
Fwiw, my radio bezel is coated in plastidip and has been for about 6months and all is well with no peeling or anything.
I would imagine that PD would be a similar finish to the factory stuff... Ad you wouldn't be limited to just black, either...
And if you add coats, it will be plenty durable...
5 coats- recommended by DipYourCar.com for durability and peelability(capable of withstanding a car crash)
8 coats- generally found to be durable enough for high use areas...
15 coats(MegaDip)- pretty much indestructible, slightly harder to peel, but easier to peel in one piece, if that makes sense...
