- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Think I'm coming to the end of my run with this 2.9
No way I can afford to swap to another engine, can't afford to throw mega bucks at this engine. This one just seems to be slowly going downhill.
Here's the deal. Maybe someone can help me make sense of this.
Several things in the past I've been trying to work out.
First is the odd 'white' smoke that appears upon starting the engine. Takes a few minutes after it starts--It slowly goes away after a few minutes. If I drive the truck daily? This white smoke isn't quite as bad. Leave the truck for a few days? And it's pretty bad.
I've had a pressure tester on the radiator--It seems to hold pressure and does not look like anything is leaky (other then the heater hose on the water pump has a slight seep)
Start the engine up and remove the radiator cap when the engine is stone cold. It burps out about a cup of anti freeze. It acts like there's pressure, but there are no bubbles present, nor any exhaust fumes. Didn't think that much of that test, as I've seen that a lot on older cars/trucks. Plus when the cap is off? The coolant doesn't start spilling out after that first 'hiccup' (now let it get to the point the thermostat is getting ready to open? And then it starts to expand and dump a bit. Again, normal from what I've seen from other older engines..once the stat opens? Then the level drops a bit and holds.)
When the engine starts up, it acts like it has one or two severe misses. It also seems to bog down badly. Same if you start it and then try to drive before it has a chance to hit "closed loop" (aka, warmed up all the way) It runs like an ignition skip--bogs down... Once it gets to temp? Everything seems to run fair...the engine retains a slight running rough idle, but is responsive. When it shuts off--the engine does so roughly.
When cold the engine also has developed a really bad idle surge. First start it up---and it goes from 1400rpm down to 900....almost like in cycles. Did not find any sign of a vacuum leak (had the same thing happen a few years ago--turned out to be the check valve in the booster and the rubber seal went bad. Replaced both, checked good)
What's been done so far, and recent replacements:
Installed a new thermostat back to 195 (used to be 180-185) Problem seemed to get worse....but it wouldn't explain all this stuff happening with a cold engine.
Pulled injector rail and manually cleaned all injectors.
Checked fuel pressure. Holds 32lbs at idle and when line is removed holds 42 lbs. No sign of fuel in the vacuum line.
Compression checked. All cylinders reading 160-170ish. Nice and even.
Spark Plugs checked, rechecked, checked..... All slightly worn--but still in excellent condition. Drivers side front plug was the only one that looked 'odd' with a matte black finish on the tip. The rest all had a light shade of gray. No sign of 'carbon' or soot. (black matte finish is clearly not 'flack' carbon....more like someone took a magic black marker to the plug tip)
Vacuum checks as follows: Upon first starting the engine struggles to hit 18ln. Holds an even 15ish....warms up and stops stumbling and holds 18-19 even. It still acts like it's being "held back" when taking out for a test drive when cold.
CEL is not on during any of this. I have yet to pull codes, but the CEL has never come on, except during the start up self test bit.
I've used a mechanics "ear" and started the engine up and listened to each injector to ensure they are firing. All have a pronounced "tick" as expected.
Did a power balance test--did get shocked by one of the plug wires. When examined while running this plug wire is not arcing to ground--it was the plug wire removal tool that bridged the gap with the pin hole to ground. I mention this in passing, as it was recent with the tool nipping the boot. (It was doing this odd running stuff prior)
Pulled the cap and inspected for carbon tracking...didn't see anything odd.
Clearly "water" is getting somewhere into the combustion system. I can't figure out where. The engine seemed to "hydro" lock a few weeks back, it cranked 1/2 a turn and seemed to lock up. It finally started up, did it's white smoke bit..and ran decent afterwards. I checked and double checked, and can't see where any coolant is leaking into the system.
As a side bar note. I did have to wonder about about maybe the map sensor? So I had the engine running..and pulled the vacuum line. No sign of any 'gel' in the line--and the engine died soon as the line removed. (it would not restart until I reattached the line.)
The TPS was replaced a little while ago--so that part should still be decent. And it does not show any sign of 'dead spots' when I'm driving.
As a further note. The converter(s) are fine. This problem has become worse over time--and I did have the muffler off recently to replace it. I had a good look at the converter bed, and it's good. No sign of any restriction with the exhaust.
At this time I'm pretty well spent. The only other thing I can think of is just saying screw it and replacing the intake manifold gasket--maybe the head gaskets.. I'm just tired of throwing parts at this enigma.
Any ideas or suggestions? Please let me know. I can't afford the $$ to throw parts at random anymore. Sorry if this seem a bit random, but I went off memory so far and it was hit/miss and I wanted all the details to be good.
S-
S-
