tortion bar cranking question
jdmpropels
Ive been searching and havent really found a clear answer.
I have a 2001 ranger edge with 90k.
The back sits at 35'' front the ground to the bottom of the fender flare and the front is at 32 1/2'' inches at the same measuring points.
Id like to level my truck out but from what I have read it seems that 2 1/2'' is too much to crank my bars.
Also Id like to get a 12.50 tire do I need a 8'' rim or a 10'' with that said I dont want the tires to stick out real far maybe a inch inch and a half at most I dont want it to look like a roller skate going down the road.
When the truck is level, the top of the rear flare will still be higher than the top of the front flare. It is simply the body style. Turn it up 1.5" and call it good.
+1 it should look much leveler with just a 1.5" crank, and concerning your rim question, I'm running an 8 inch rim with 33x12.50s and they stick out about an inch , inch and a half, on my 99 so that might be what you want to run, oh and I'm running 4 inches of backspacing with 15x8 cragar soft 8s
